Hide serial number from LabVIEW startup screen.
smercurio_fc wrote
 This would basically prevent Joe Smith grabbing the serial number of a corporate license and activating their license for home use
NI struggle with the same problem, as Microsoft, Borland, Autodesk, and every other manufacturer of popular software. It is always some smart people who will find a way to bypass the copy protection of the software. And then they do it, the "fix" will spread it self in Cyber spaceTo get a valid serial number is not an issue in this case.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 21 of 36
(2,211 Views)
Actually, it's us regular users who struggle with the problems of copy protection. Sometimes it feels like copy protection is put in place to punish those who do things right. Those who steal are rarely, if ever, flummoxed by this copy protection stuff. In fact, sometimes their life is a little better.
Message 22 of 36
(2,200 Views)
smercurio_fc wrote:
Well, so far, the NI police haven't come barging through our door. I'm frequently reactivating LabVIEW due to reinstalls. If NI is keeing track of me, let me just wave a hello to them. Smiley Happy
Besides, I doubt that there's really an "activated too many times" limit. In the scenario I gave where activation reoccurs because of a reinstall, why would NI care in the first place? If it occurs because it's being installed on multiple machines, remember that the license agreement allows you to do this (I'm referring to having a named license). What matters is whether it's being activated by a different party/owner, and I think this is what the point of the question is. I would agree that it makes little sense to display the serial number in the About dialog. That information can be found via the license manager. In a corporate environment you could go one step further and restrict access to the license manager application (say with OS security access control lists). This would basically prevent Joe Smith grabbing the serial number of a corporate license and activating their license for home use.
I think NI can differentiate between reinstalls and installing on several machines because it creates a unique ID for each machine based on the hardware like Windows does.
I know the license agreement allows more than one installation but there has to be a limit.
What's to stop a company from buying one license for five or ten developers? (besides ethics and fear of a disgruntled employee reporting them)
=== Engineer Ambiguously ===
Message 23 of 36
(2,188 Views)
@smercurio_fc wrote:
Actually, that's not the number I, errr..., I mean this other guy that I know would have used if he ever did such a thing. The number used follows the same format, though, so you probably could make any number you wanted, as long as you followed the format.
I always used my birthday encoded as serial number in those old days. Of course with a legal license but it saved me from remembering an arbitrary series of numbers Smiley Very Happy
Rolf Kalbermatter  My Blog
Message 24 of 36
(2,150 Views)
@RTSLVU wrote:
I bet LV occasionally phones home and checks its license status and any installations using a now revoked serial number would be disabled.
Until now, the only time NI software phones home is if you register that software and allow direct online registration. The NI mechanisme does most likely do some extended plausibility checks on registration, such as that the same serial number is not registered for different organizations or company names besides the obvious of counting individual instantiations of the same serial number. Together with the hardware key that is produced they also have a pretty good way to detect multiple registrations for the same system or for different systems.
I'm pretty sure that you can register LabVIEW umpteen times for the same hardware key before any alarm goes off, but you may get a phone call soon if you attempt to install the same serial on more than lets say 5 different hardware identifications.
Message 25 of 36
(2,149 Views)
A friend of my once installed some very expensive NI software. That he had been given by some customer to do some work with. Do not remember which Labview system as it is some years ago. Around Labview 8.2. He told me that NI had called up the customer to check what was going on. In this case it was no big deal since the installation was cleared with the locale NI office. But they do some checking after all
Message 26 of 36
(2,124 Views)
I accidently discovered something: The serial number seems to be only required for activation, not for installation itself. If you don't use automatic activation you can enter whatever serial number you want on installation, you just have to use your real one when you activate it.
Message 27 of 36
(2,116 Views)
This is normal. You can even install without any serial number and it will be in evaluation mode.
If you don't activate, it will stop working after the evaluation period has expired.
Message 28 of 36
(2,076 Views)
Yes, but it's a way not to reveal your serial number in the splash screen: Install LabVIEW using a fake serial number and use your real one for activation only (by phone, mail, or browser). Your activated version will show the fake serial number in the splash screen.
However there's something about the serial number that annoyes me much more: When I receive an upgrade from NI by snail mail it's printed on the envelope so everybody can read it...
Message 29 of 36
(2,043 Views)
Ah, I see what you mean....
...then make sure you support the idea mentioned above. 😄
Message 30 of 36
(1,977 Views)
