Hide / show grid in a graph programmaticly
I would like to hide / show the grid (minor / major) progammaticly. I try to create a property node, but I don't find the way to access the 'hide' property... Thanks.
(3,708 Views)
you can create a property node and set the grid color to transparent or to a visible color to simulate hiding and showing.
pat
(3,708 Views)
I might need corrected, but I don't believe you can change the 'minor' grid color, but yes on the 'major'.
Its a Write-to property node called Grid colors, and you can have the X & Y grids as separate or Clustered together elements. You'll need to add 2 color boxes [Controls > Numeric palette] to your front panel (X & Y). The user's selection is a numeric value sent to the property node(s) you wired.
Good Luck with it, Doug
(3,708 Views)
