Hide single plot in graph
I have a graph with 16 Plots and I want programatically to hide 1 of them with a Boolean switch.
I've tried with the plot property node but I can't figure out how can I select a specific plot.
Does anyone know how to do it ?
Kobi Kalif
Software Engineer
(5,079 Views)
Accepted by topic author Kobi_K
you have a property node "Active plot" : set it to the number of the plot you want to change the visible property.
Best Regards
V-F
(5,073 Views)
Hi Kobi
The 'Plot Visible' and 'Active Plot' property nodes of a waveform graph should be all that's necessary, I've attached a really quick example.
Kind Regards
Chris | Applications Engineer NIUK
(5,067 Views)
Hi Chris,
thanks for the example but i have LV 10 so i can't open it 🙂
thank you any way for your help.
Kobi Kalif
Software Engineer
(5,064 Views)
Hi Kobi
Sorry about that, I've edited my original post to include a version which will run on the LV10.
Kind Regards
(5,059 Views)
