Hide splitter bars
I know you can't make splitter bars transparent. But, I have an X Control which is set to scale with the pane. When it grows, things work fine but the splitter bars extend and it looks awful. Any suggestions? Maybe some kind of decoration to cover them.
Edit: I can't just resize the X Control facade smaller, because then I don't get the alignment on my graph correct. It will cut off the X Axis Label. I want the bottom of the graph to align with the bottom of the listbox, not the bottom of the graph bounds.
Message 1 of 9
(6,733 Views)
This is what it looks like if I size the X Control facade so I don't see the splitters when it grows. I think it looks pretty bad. This is with teh bottom of the graph bounds aligned with the listbox
Message 2 of 9
(6,718 Views)
Accepted by topic author GregFreeman
you can make the Classic splitter bar the same color as the background of the front panel...essentially making it transparent.
aputman
Message 3 of 9
(6,695 Views)
Yup, for this to work you will need to programatically read the owning VI of your XControl, get the pane of that owning VI that the XControl is in, and then using the references to your splitters, change the color.  Sounds like a bit of a pain.
Message 4 of 9
(6,683 Views)
Or just paint it....assuming you won't be changing the background color.
aputman
Message 5 of 9
(6,677 Views)
Why would you assume that?  I don't know what kind of front panel an XControl is being placed on.
EDIT: Maybe I mis-understood, where the splitters would be.  If they are in the facade and that doesn't change color then yes, make it the same color as the background.
DOUBLE EDIT:  Also there is this idea for a 0pixel splitter
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-0pixel-size-splitter-bars/idi-p/1229909
Message 6 of 9
(6,671 Views)
You said it sounded like a lot of a pain.  I was just removing the pain.  Smiley Happy
aputman
Message 7 of 9
(6,661 Views)
Yeah it is a pain working with panes for sure.  But honestly it is the best tool LabVIEW has today to handle window resizing.  Which is a little unfortunate.
Message 8 of 9
(6,651 Views)
Old thread I know but I just found a different solution.  You can color the splitter the transparent color (0d16777216) and when the XControl is placed on a front panel the splitters will be transparent, and will look the color of the front panel on the new VI.  In the non-running Facade the splitters will look black.  The panes themselves by default should be transparent if the VI properties are set as described here.
Message 9 of 9
(5,350 Views)
