Hide striing text box
Iwas just wondering if there is anyway to hide and unhide the text boxes in labview when the program is running?
I am using a case structure and i want it to show the text box with the answer when its true but i want it to be hidden off the screen when it is false. Is this possible?
Adam
(4,127 Views)
Use the visible property node.
Right click on the string and select create - property node - visible.
Hope it helps,
Paulo
(4,125 Views)
here is a quick example:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,103 Views)
Hi Adam,
instead of (un)hiding a text indicator you can write the answer string to the indicator in the true case, otherwise wire an empty string constant...
(4,100 Views)
