Hide the EXE Name in the Task Manager
Dear all,
             How can i hide the Exe Name in the Task Manager.
Thanks.
Sivaraj M.S
CLA
(3,134 Views)
Check this link
http://forums.ni.com/ni/board/message?board.id=170&message.id=404647
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,118 Views)
Hi Balaji,
              i am asking how to hide the exe name in task manager.
 http://forums.ni.com/ni/board/message?board.id=170&message.id=404647-----> This link is hide the taskbar only.
Sivaraj M.S
CLA
(3,113 Views)
Hi siva_usic,
see this link please http://forums.devx.com/archive/index.php/t-65734.html. It should also be possible with LabView if you call the correct dll's.
Hope it helps.
Mike
(3,104 Views)
