Hide the Radio Button Container
Is there any way to hide the Radio button Container? Why do Radio Buttons only come with a "Modern" container? I have tried making it transparent but there is always container artifacts left over.
The "Modern" controls and indicators with their sunken frame remind me of the 1970's when every "Modern home" had a sunken living room, in other words it looks very dated.
Now I think I remember why I never used Radio Buttons all these years
=== Engineer Ambiguously ===
Message 1 of 17
(5,880 Views)
Accepted by topic author RTSLVU
Use the classic radio buttons, set the background transparent and replace the controls with the button style of your choice.
aputman
Message 2 of 17
(5,866 Views)
Thanks, I didn't even see those in the Classic set.
Message 3 of 17
(5,857 Views)
You can actually make Modern frames completely transparent; you have to select the "foreground" explicitly.  Easy, but only once you discover it.
You can also easily swap out the Modern frames using "Advanced>>Customize..".  Below I switched to a Silver rounded box as the frame.  Again, takes some effort to learn but then is easy.   Also show below is my "Segmented" control from Flatline Controls, which is a customized Radio button with (heavily) customized System buttons.  It's nice to have a frame of some type, as it shows the User that the controls are grouped and not independent.
Message 4 of 17
(5,855 Views)
Yup. 😄 (Sliver buttons in a modern radio frame here)
(same for other moderns containers (cluster, array, etc.))
Here's your VI After editing exclusively using the coloring tool. 😄 (no container swap, etc.)
Message 5 of 17
(5,844 Views)
There are several flat controls in a few toolkits that I think meet this need.  JKI and Flatline are two which look super slick and have radio button functionality, while looking like other buttons.
Message 6 of 17
(5,838 Views)
How?  No matter which part of the control I select, it will not go transparent.
aputman
Message 7 of 17
(5,828 Views)
Paint Brush; Right-click on frame; hit "F" key to switch to foreground; select Transparent.
Message 8 of 17
(5,824 Views)
aputman
Message 9 of 17
(5,819 Views)
@drjdpowell wrote:
@aputman
That's a new one for me and does not seem to work here.
I always use the <space bar> to alternate between "BG | FB | BG&FG" in the coloring palette.
It's even documented ...
Message 10 of 17
(5,817 Views)
