Hide the drop-down menu for the pict ring
I am working on a project where I use picture ring for each finger (see picture), containing finger with skin tone, red colored and green colored. I want it to work as a tri-state button, so when I for example press the thumb it'll turn green (if it's correct) or red (if it's wrong).
When I'm clicking on the finger the drop-down menu is showing. How can I remove the menu, or disable it somehow?hand_picture Ring.png
(4,126 Views)
Accepted by topic author 50616d656c61
You can make it an indicator and look for the "Mouse Down" event.
(4,119 Views)
Make the pict ring an indicator then over-aly it with a transparent boolean. When the boolean is clicked figure out whcih pict ring to show and update the pict ring.
Ben
(4,118 Views)
So you mean that I can create an indicator for the drop-down menu? I couldn't find out how to do that, what should I do?
(4,079 Views)
Go to the block diagram, right click your pict ring control, click change to indicator.
(4,064 Views)
What about using a radio button control?  Replace the default bulls-eye buttons with square flat buttons from the classic palette and put the thumb images on the buttons.
Lynn
(4,063 Views)
