Hiding/Remove the frame from an array or cluster control.
Is there a way to use an array or cluster control without a frame around it appearing on the front panel? I've tried using the paintbrush tool to make it transparent and customizing the control so the frame size and position were different from the content area with no luck.
Thanks in advance
Message 1 of 9
(7,307 Views)
Yes!
Use the array and cluster containers from the "Classic" pallette.
Just color them transparent.
Ben
Message 2 of 9
(7,303 Views)
Thanks in advance
You probably missed something : try again with the paint brush, right-click the cluster border and hit the space bar while choosing the color. That way you can apply a different color for the foreground and the background. Things might be easy with oldstyle (2D) "Classic" clusters...
CC
Chilly Charly    (aka CC)
Message 3 of 9
(7,303 Views)
😠 Harrrrrr ! Too late, one more time 😄
Message 4 of 9
(7,300 Views)
Sorry about that CC!
I bet you spell checked.
Ben
Message 5 of 9
(7,295 Views)
Ben
you win (wan ? won ? wonned ? waned ?...)
Message 6 of 9
(7,287 Views)
Using the classic controls fixed it right up.
Message 7 of 9
(7,272 Views)
Just color them transparent - give me please code's example
Message 8 of 9
(6,773 Views)
Duplicate Post.  And in what version of LabVIEW do you want it?
And why don't you just try the instructions listed above to modify an Array yourself.  You might learn more by doing than by having it done for you.Smiley Wink
If you don't know how to use the color tools in LabVIEW, perhaps you should take some tutorials.
Message 9 of 9
(6,765 Views)
