Hiding taskbar icon.
When I launch MS Access using ActiveX in Labview, I can hide the window of Access using Property node with property visible = false. However, this doesn't hide the Access icon in the Windows taskbar. How can I hide it? My goal is to make the communication with Access invisible to the user of my programme.
(4,604 Views)
"Tifa" wrote in message
news:50650000000800000076220000-993342863000@exchange.ni.com...
It'll be easier to hide the whole taskbar.
George
http://george-zou.sinacity.com
(4,604 Views)
You can use the hide window option of the show window fuction in the
user32.dll for windows. Docs and help at vbapi.com.
http://vbapi.com/ref/s/showwindow.html to be exact.
You may also need to hide the additional taskbar entry that labview adds by
default.
Do this by adding HideRootWindow=True to your labview or exe ini file.
Mike
----- Original Message -----
Newsgroups: comp.lang.labview
Sent: Monday, June 25, 2001 3:45 AM
Subject: Hiding taskbar icon.
> invisible to th
(4,604 Views)
