High-resolution spectrogram around a known carrier frequency
Dear all,
I have trouble using the STFT spectrogram VI. I have a waveform which consists of multiple pulses at different frequencies. A mock-up waveform could be the following:
However, in reality the pulses have much closer frequencies, e.g. (4 GHz) and (4 GHz + 40 MHz). Since I know my carrier frequency (4 GHz) and the maximum offset that could occur, how can I limit the STFT spectrogram to look e.g. only from 3.9 GHz to 4.1 GHz?
I have created a little mock-up VI and attached it to this question. It seems I need to downconvert somehow but I can't really figure out how to do that.
Thank you very much for your help!
Peter
(1,141 Views)
First : How about a first down mixing?
next: the frequency resolution of FFT is based on the signal duration ...
how about:
detect and cut out the pulse
downmixing with carrier
a phase demodulation ..(IQ signals into arctan2, phaseunwrap)
a frequency shift results in a ramp , detect and fit the ramp(s) ..  ?
Looking into RADAR papers ? 😉  I'm not a RADAR guy... but I work a lot with PM signals.. so that's my hammer on that nail 😄
Greetings from Germany
Henrik
LV since v3.1
(1,097 Views)
