Higher sample rate
I was wondering if I could take samples up to around 5000Hz. Which adjustments do I have to make? Now it is going very slowly.
Thnx Simon
(2,929 Views)
Hi Simon,
read the manual of your device, which is connected by Modbus. It should contain information about samplerates…
(2,922 Views)
Can this be done with a loop. Can't find any information.
Simon
(2,917 Views)
Hi Simon,
What is "very slowly"?
What is the specification for your device?
You already use a loop: why do you want to use more loops?
Right now your loop is set to iterate at 1kHz: when it runs (much) slower than the limiting factor is the reaction/communication time of your device. Again: read the manual of your device…
(2,898 Views)
And since you provided us no code (meaning a VI, from which we might be able to "pull" information not found in a picture) nor any clue about what "device" you are using, how can we possibly help you?  You have provided us with no information!
Bob Schor
(2,891 Views)
