Highlight a row in table
I have loaded a spreasheet file into a table and the data is displayed correctly.
I am now trying to highlight the first row of data  in the table - do something -  then the second  row etc. This should ideally be from a loop counter.
Any ideas?
(6,836 Views)
This will highlight 6 columns in a row, then increment to the next row. You could also use the BG color of the cell to get a more dramatic highlight effect.
Message Edited by AndrewAlford on 02-03-2006 08:58 AM
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(6,827 Views)
I've tried the above code and it works. In my case not all the rows of a big table are visible  so I have a vertical scroller. How do I make sure that every time i highlight the row it is visible to the user. Basically I need to automatically scroll through the table so the highlighted row is visible to the user. Any ideas about that?
Thanks.
(6,590 Views)
Use the index values property to set the visible lines.
Jim
LV 2020
(6,578 Views)
Use the property IndexVals (Index Values), this sets the column and row that is first in the upper left corner of the table.
Andrew Alford
(6,576 Views)
