Highlight top row of multicolumn listbox
I am using a multicolumn listbox as an explorer window.
How can I ensure that the first item in the listbox is always highlighted when I double click on the folders to drill down?
(2,839 Views)
Write a 0 to it. If you were to wire a numeric indicator to the listbox, you would see that the value is equal to the highlighted row. You can write to a local variable or value property of the listbox.
(2,837 Views)
(2,826 Views)
