Hii everyone!! I want to design a vi related to iir filter
1. The user  need to provide a and b coefficients  and the vi should analyze the poles and zeros and  represent zero-pole plot which also includes magnitude and phase plot.
2. After that from the poles obtained one after another pole need to be eliminated and we should analyze the zero-pole plot  of remaining poles   and zeros and  obtain its magnitude and phase response of it.
3.after that 2 poles must be eliminated following the same process. finally the  poles and zeros with highest stability should be chosen
I HAVE COMPLETED THE FIRSTSTEP .can someone help with the second and third step
(899 Views)
What have you tried and where did you get stuck?
Note that there are probably easier ways to create a unit circle, right? (note that the rotation will be different, but you can correct by making the ramp from 2pi to 0, for example)
(890 Views)
i..e  obtaining the zeros and poles  and magnitude and phase response .
and then  we can eliminate the poles one after other which can be done by using delete element function from array palete .Now i stuck at this point where the further analysis of remaining poles and zeros should be done and displayed on frontpanel.
(878 Views)
