Hilbert Transform for FPGA
I am currently struggling trying to recreate the Hilbert transform onto the FPGA keeping all the numbers to a maximum of 32bit and the processing time to a small enough tick count that I can run two signals of 100KHz through it.
I have a working system in LabVIEW windows but am really having issues when trying to only use integer numbers.
I am trying to calculate the Hilbert transform of real-valued function
Xr (t)® Xˆ (t)
the analytical signal:
X (t) X (t) i Xˆ (t)
and the instantaneous phase and frequency. Unfortunately this is proving more of a challange than I was hoping so was wandering if anyone had any ideas. I have attached all of the equations I am trying to reproduce, just dont think my maths is currently up to standards. Thankyou.
Pete
(5,921 Views)
post your labview working code.
Stu
(5,893 Views)
Hi, Attached is the code,
The problem I am having is that this needs to be implemented not only on FPGA  but on a point by point basis so that I can implement the instantaneous phase and frequency on my latest signal value and calculate my desired output , a pulse of one or zero based on the most recent value I have recieved. I have tried doing a FFT input, multiply by -j and FFT-1, instead of the hilbert, though I am having problems merging the buffers that the two are using so that it functions as a point by point system on the FPGA.
Thank you.
Peter
(5,874 Views)
Ok,
Slightly easier way of solving this problem but still need it sorting. Basically i am sampling an input at 10Khz on the FPGA, I cannot transport this up to the RT as wont have time, the RT is already doing other things.
For every reading I need to get the hilbert transform.
This can be achieved by doing an FFT, multiplying by 1j and then doing an inverse FFT
currently the FFT needs to store a buffer of the data so is consistantly leaving me a buffer behind.
I am trying to implement them on a point by point basis so that I can get the output of the latest individual sample at any one point.
regards
peter
(5,823 Views)
Take a look at the Signal Processing>>Filters>>Advanced FIR Filter>>Parks-McClellen.vi
This vi, when given the appropriate inputs, should provide the FIR coefficients needed for a Hilbert Transformer filter.
Randall Pursley
(5,810 Views)
