Hold off DMA transfer
 I have a DMA connected to a SPI driver. The device on the other end of the SPI bus (the slave) gives a sync signal telling when data it is outputiing is valid (As it outputs trash before before hand). I was wondering how can I suspend the DMA transfer based on the sync signal?!. Any data already in the DMA should still be sent to the host even if its input is suspended at a give time.
Hopefully this question is clear ;0
Thanks 😉
Message 1 of 1
(2,284 Views)
