Hole in Wall - Deleting an Array of Indices from an Array of Indices
The very first two elements of "Wall Indices" are the same (3878).
The original code passes both values through since 3878 isn't a "hole" which is why it gives an answer that is 1 larger in size compared to the Map/Set examples. If 3878 was a hole, the original code would only remove the first instance while Map/Set would remove both.
Message 11 of 18
(745 Views)
(Sorry, could not look at your VI, so maybe I misunderstood)
<content deleted>
Edit: Sorry, I misunderstood the problem...
Message 12 of 18
(722 Views)
@BertMcMahan wrote:
Well heck then, here's a much simpler version:
Here's an even simpler version.
~20ms in my testing (on a W10 VM where your solution is about 100ms) producing the exactly same result as the original code.
Message 13 of 18
(706 Views)
@LuminaryKnight wrote:
So I'm not entirely sure I follow what you're trying to do here.  Let me know if I didn't duplicate it correctly.  But this nearly broke my machine.  Filled up  my memory instantly.
That looks correct to me. I just tried with 500k Wall and 10k holes and it was almost instant. It is Array Subset you're using, right? (The picture i posted was a Snippet, if you save it to disk you should be able to drag it into a VI and get the code)
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 18
(662 Views)
Version 2, with Maps ... i just realized it's basically identical to Altenbachs ... i guess that's a good thing. 🙂
Qestit Systems
Message 15 of 18
(659 Views)
It does not preserve the original order of the elements. You also need to be careful if the input is a diagram constant, because the entire thing could potentially be constant folded once debugging is disabled, making any benchmarking meaningless.
Whenever I hear "almost instant", I am reminded of the comic Steven Wright who once said: "I put instant coffee in a microwave oven and almost went back in time" (The joke made sense back in the time where these ovens were touted as being so much faster than regular cooking.)
I was using a Set, not a Map (small difference)! 😄
Message 16 of 18
(636 Views)
Greatly appreciated.  I did not even know these functions were available.  Adding new stuff to my bag of tricks.  Thank you everyone!
Message 17 of 18
(589 Views)
Sets and Maps are extremely useful and relatively new (introduced in LabVIEW 2019 and probably first suggested in 2010 😄 ).
For an overview, check my presentation.
Message 18 of 18
(587 Views)
