Hololens and Augmented Reality
Here are three projects showing the first results obtained with the Microsoft Hololens and a LabVIEW toolkit in development. The Microsoft Hololens is a untethered Augmented Reality Helmet. Go to hololens.com for more details.
I am looking for feedbacks: comments, ideas, suggestions, etc. before completing the toolkit.
Introduction to the Hololens toolkit
Hololens demo with a Robot
Hololens in a NDT Application
Marc Dubois
(4,347 Views)
Looks very interesting! Right now I just imagined a special add-on to your toolkit, a kind of "label-up and show in AR" application. We have several large glove-boxes with hundreds of hand valves, flow controllers, pumps, pressure/temperature/etc sensors. It is very often happens that even an experienced operator spends minutes with finding a particular object in the glove boxes. Even with the help of the 2D P&ID...
I imagine such system to use in similar environments, but I am not sure about the limitations/difficulty level to create a working solution. For example, using such helmet, the software would show AR labels in the field of view... or if the user searches (speech recognition? 🙂 ) for a particular hand valve, the hololens helmet would guide him/her to the exact location...
It would be also very useful if the toolkit could load/read an existing 3D drawing (CATIA, AutoCAD, etc.). After that only some reference points would be required (corners of a glove-box for example, special markers?), and the application "would know" what is there where the user looks...
(4,232 Views)
thank you Blokk for your feedback.
Currently, my idea is to have very limited capabilities in the Hololens itself. The application running on the Hololens is just a client receiving 3D objects from the LabVIEW application. Therefore, if you can load a CAD file into LabVIEW as a 3D object, it can be seen in the Hololens. The 3D object is positioned in the AR world by LabVIEW.
The question of positioning the AR world with the actual world is a good one. It is possible to use some objects (like a pipe) or the floor as scanned by the Hololens to align the worlds.
I like the application you propose. The Hololens has speech recognitions capabilities but I have not looked at it yet.
Marc Dubois
(4,229 Views)
Marc,
Can you visualize "live" plots of data?  I want to overlay a real-time scope-trace on a physical object.  Does this toolkit provide this capability?
John
(3,841 Views)
Yes, an image can be uploaded to a window (called panel) that can be updated at a rate of at least a few hertz (depending on the image size). One of the examples provided with the provided with the library demonstrates that capability.
Let me know if you have more questions.
Marc Dubois
(3,836 Views)
