Hon can I creat an active x with mulatiple select cell and multiple value or data output.
I have an acive x that can read and retrieved the value in a specific cell from excel to labview. Now I want to get atleast 20 values in diff cell from excel to labview and can also pass 20 values to labview.
Thank you
(can i have a simple example, please?)
(2,753 Views)
Hi Julro,
Have you looked at the example supplied with LabVIEW.
'C:\Program Files\National Instruments\LabVIEW\examples\comm\ExcelExamples.llb\Write Table To XL.vi'
I know this is a write to excel but all you need to do is modify the Set CellValue.vi so that you read the value and you have yourself a Get Cell Value.vi.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(2,753 Views)
You should use the Range method of the Worksheet and select the beginning and ending cell. Then, read the value of that range.
I attached a simple examples that allows you to specify which sheet and which cells you want to read.
Zvezdana S.
(2,753 Views)
