Honeywell UDC 1200 Controller
I am trying to interface a Honeywell UDC 1200 controller to a Labview VI via a RS485 connection. More specifically, I am trying to control/program the controller output. Are there VI drivers or subVI's to assist me in this task?
Any help would be greatly appreciated. Thank you.
(4,049 Views)
Quick search will help you all the time. Post back if need more specific help.
Mathan
(4,046 Views)
Mathan,
I did search the other threads. There was some information; however, the only subVI library posted was for version 5 and I am running 8.6. Labview was not able to revert back to open the older library.
Any other help?
(4,031 Views)
axi_mach2 wrote:
Mathan,
Post the specific library here or just give the link where you find that and somebody here will convert it for you so that you can open in LabVIEW 8.6
Mathan
(4,028 Views)
Mathan,
I have attached the library that was posted on another thread for the UDC 2500. My hope is that it will be compatible to my UDC 1200. Can you convert it so it works for Labview 8.6 please.
Thank you so much for your quick responses.
(4,025 Views)
