Hoovah Vector CAN Api flush requires extra instructions?
Hello
I'm using the can api developed by Hoovahh, it works correctly.
The problem is that actually I'm sending over 200 can messages, some messages has differents cycle time so I'm using DQMH to launch different clonable modules depending the cycle time. The problem is due the quantity of messages sent my vector can case has an error (XL QUEUE IS FULL) so I've added a logic reading the error after send the message, if I receive the error mentioned before, I send a Flush TX (From Vector Hoovahh API) but the queue continues full. My doubt is the following, an additional step is required to do the flush works correctly?
Message 1 of 1
(413 Views)
