Horizontal Histograms with text descriptors on y axis
Does anyone know of an easy way to display data using a horizontal bar with a text description to the left on the y axis?
For example I have the following table.
Description               Quantity
T-widgits                   50
A-widgits                   23
Y-widgits                   13
I want the descripton on the y axis and the quantity displayed as the bar graph.
Message Edited by nate on 06-23-2006 08:16 AM
(2,993 Views)
If you have the spc toolkit, there is a rotate graph vi for histograms.
C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\addons\SPC\0spcctls.llb\Rotate Graph.vi
(2,988 Views)
You might be able to use cursors for each set of data. Use the cursor name for your category labels. I think you can use property nodes to adjust the position of the text.
(2,983 Views)
Here is a sample with cursor labels. Not exactly on the left side of the axis but it might work.
(2,975 Views)
