How Can I do an executable program in Labview?
I have Ver. 6.1 of Labview, Ver. 6.0 of IIMAQ Vision Builder and PCI1409, I have my aplication ready too. But I want ti create av executable aplication.
I wanto to Know If is necesary to have a special version of LabView or to have another software, and Where can I find an examples about it.
I will hope your answer.
(2,954 Views)
To create an executable with LabVIEW 6.1 you need the application builder add-on. This comes with some versions of LabVIEW (e.g. Professional) and not others (e.g. Base or Full). To find out if it's included with yours go to the "Tools" menu on the front panel and look for the "Build Application or Shared Library (DLL)" option. If you don't have it you can probably purchase it seperately.
Also you need to have the LabVIEW 6.1 runtime engine installed on the target computer you intend to run the executable on.
Hope this helps,
Neil
(2,954 Views)
