How Can I reset the i in the while loop to 0 after i=15 each iteration?
Hi members,
I want to ask how can I reset the i in the while loop to zero after i reach 15 in labview..
I want always to reset the i to zero after i reach 15.
your help will be highly appreciated
(3,915 Views)
Hi Tasnim,
you cannot reset the "i" (iteration counter) in the while loop.
But you could apply simple math on the value delivered by i: when you want to count up to 15 and then start again with zero (like a sawtooth pattern) then a simple modulo operation (using Quotient&Remainder) will be the solution!
(3,894 Views)
0-15 can be done with an AND. I AND 15 will result in 0-15. On an FPGA, that will be much more efficient than a Q&R, that potentially requires multiple iterations.
On an FPGA, you'll also run into the problem that the i will reach it's max value pretty soon. You'll get that on a PC as well, but it can take a while... On and FPGA running at 40 MHz, the 31 bits become a problem after 53 seconds. IIRC, on FPGA, the i will stop at it's maximum value, on a PC it will wrap to the min value. Not sure...
I'd consider for a shift register for any code except the most trivial. Increment the value when approprieate, and use Q&R or AND to get the effect. This will be more flexible in the long run, as the behavior is decoupled from the loop counter.
(3,869 Views)
If your loop runs extremely quickly (typically on FPGA) you might instead consider a Shift Register and a select node with equals 15 comparison.
GCentral
(3,867 Views)
I will also throw in my vote for keeping your count in a shift register.  As stated, only truly necessary if in an FPGA, but anything running a long time should use the shift register method instead of the iteration terminal.
(3,814 Views)
Just in case the base courses where skipped:
(3,677 Views)
