How Can I see the BlockDiagram of a password protected VI
I need to modify some VI but I can to open the Block Diagram because are password protected.
I can to find into the forum tahn can help.
Any body has an I dea how?
(3,147 Views)
The only way to view the block diagram of a password protected VI is to enter the correct passsword.
(3,140 Views)
This has come up several times before. See here, for example. You can always try the brute force method: keep guessing.
(3,138 Views)
I nearly learned this lesson the hard way: If you have something you want to distribute but need to do it securely, then keep a backup copy that is not protected by the same means. Example: email yourself a copy of the unprotected file (not for extremely sensitive stuff, of course) or save it to a flash drive that you can lock up. Bottom line: never depend solely on your memory for these things. 🙂
____
Ryan R.
R&D
(3,102 Views)
