How Can I use the a textbox as both a control and indicator at the same time.
I want to use a configuration file for my application and be able to change the configuration from the front panel if needed. If I use a textbox I have to use it as a Control when I read from my config file. When I write  the settings of the same textbox to my config file, it need to be an Indicator. How do I handle this.
(2,650 Views)
Write to a local variable of the textbox.
(2,646 Views)
