How Do I Convert A (0,1) To A Boolean in LabVIEW?
I would like to convert  an array of (0,1) to boolean.
I did not find the function in LabView. There is only the function boolean to (0,1).
Gnaoui Bouchachiya
(13,969 Views)
Hi
For this you could use the type cast function.
Thomas
Message Edited by becktho on 11-30-2006 10:40 AM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(13,961 Views)
Or something like this:
Note that for floating point types you usually need to compare a range.
Message Edited by tst on 11-30-2006 12:32 PM
___________________
Try to take over the world!
(13,952 Views)
@tst: 5 stars to you - the most obvious is always so far away 😉
Using LV8.0
(13,943 Views)
I agree with Becktho that tst's  solution is better since bechktho's is limited to U8 and I8
Ton
My LabVIEW Ideas
(13,936 Views)
thank you
Gnaoui Bouchachiya
(13,924 Views)
