How Do I Trim A string from the leading spaces?
i.e " XXX " ==> "XXX"
Thank you How Do I Trim A string from the leading spaces?
Thank you
Message 1 of 10
(6,143 Views)
Use the "Search and Replace String" function from the string palette to search the string for spaces and replace them with nothing. Make sure you set the "replace all?" input to true, or else it will just replace the first space. The output will be your string without spaces.
Brian
Message 2 of 10
(6,143 Views)
thanks Brian, But can I use Search and Replace String function to replace linefeed, carriage return, and spaces at the same time? I tried to do [\s\n\f] and it didn't work. It only work either. Do i need to use Search and Replace String three times to solve that problem? Answer is greatly appreciated...Bassam
Message 4 of 10
(6,142 Views)
I don't think that you can do that. When you put \s\n\f in as your search string then it looks for space, newline, and form feed to happen consecutively in that order. If you expect any of the parameters to happen together then you can combine those into one search and replace, otherwise I think you have to use seperate instances of Search and Replace
Brian
Message 5 of 10
(6,142 Views)
A brute force approach would be to use a "while" loop to go through the
string character by character checking each character using the "Whitespace"
or "Lexical Class" comparison functions. When you hit the first real
character in the string, you terminate the while loop and use the iteration
counter to split the heading whitespace from the rest of the string.
If you want to eliminate all whitespace, then simply build a new string in a
shift register, and as you test each character from the original string
either append it to the new string or not, depending on what it is. However,
using "search and replace" three times may execute faster if you only want
to zap those three characters, even though it would initially appear less
efficient.
Bassam
@no.email> wrote in message
news:506500000005000000221F0000-984882144000@quiq.com...
Message 6 of 10
(6,142 Views)
Did you remember to set the string constant to show codes?
Rolf
Message 7 of 10
(6,142 Views)
What exactly needs to be wired to the "search string" and "replace string" inputs to the block in order to search and replace all spaces. I have tried wiring [\s] to the search string input and wiring nothing to the replace string input. Is this correct?
Any help is appreciated.
Message 9 of 10
(6,142 Views)
If you know what 'XXX' is then use match pattern vi under the string palette. Enter the text 'XXX' as the regular expression and take your output off the match substring output.
If you don't know what the text is you can remove the leading spaces by wiring "[\s]*" into the regular expression (without quotes). This tells it to look for 0 or more instances of the space character. Take you output off of the after substring output.
The wildcards will allow you to make some very tricky searches quite easy.
Jared
Message 3 of 10
(6,142 Views)
>Thank you
It seems that you want to trim leading and trailing spaces.
If the string contains one word then you have two solutions.
Either
use one 'Match Pattern' function with regular expression
set to "[^ ]+"
or
use one 'Scan From string' function with format string
set to "%s"
If you want to remove leading and trailing spaces and keep spaces
between words it seems that you need two 'Match Pattern'
Use "^[\s\r\n]*" as 'regular expression' for the first Match pattern.
Wire 'after substring' from the first 'Match Pattern' to the 'string'
input of the second 'Match Pattern'
Use "[\s\r\n]*$" as the 'reg
ular expression' for the second 'Match
Pattern'.
You should now have your string in 'before substring' output of the
second 'Match Pattern'.
Remember to set the string constants as "'\' codes display".
Message 8 of 10
(6,142 Views)
Bassam;
In the Openg.org web page there is a vi that do exactly that and is called "Trim Whitespace.vi"
Regards;
Enrique
www.vartortech.com
Message 10 of 10
(6,142 Views)
