How Do I calibrate the scxi 1125 using NI-DAQmx version 7.2.0f0?
I'm trying calibrate the scxi 1125 module using NI-DAQmx version 7.2.0f0, but i can't find SCXI_Single_Chan_Setup,
SCXI_Set_Gain,SCXI_Configure_Filter,DAQ _Op. VI's
(2,608 Views)
Unfortunately, there is not yet driver support for calibrating the SCXI 1125 with DAQmx. However, you may still use the traditional DAQ calls you mentioned.
Rick Kuhlman
(2,595 Views)
Thank you for your help, Mike
I'm going to try do that
(2,590 Views)
