How Do I hide the convert dialog box from appearing when converting labview 4.x datalog files to labview 6.0.2
How Do I Hide the Convert Dialog Box From Appearing When Converting LabVIEW 4.x Datalog Files to LabVIEW 6.0.2.
(2,795 Views)
Chand,
Put the line
silentDatalogConvert=True
in labview.ini settings file
LabVIEW, C'est LabVIEW
(2,795 Views)
I tried, still it is not working. After I added this string into labview.ini I came out of LabVIEW and I re-opened the application. Still I am getting the dialog.
(2,795 Views)
It is documented here, p.4:
http://www.ni.com/pdf/manuals/321780c.pdf
If it doesn't work, contact NI Support.
(2,795 Views)
Check if the setting line is still in labview.ini. Maybe the file was overwritten when exiting LabVIEW. If so, exit LabVIEW, add the line in labview.ini and relaunch LabVIEW.
(2,795 Views)
