How Do I use 4070 with LabVIEW?
I cannot seem to find a driver or any other way to control 4070 from LabVIEW. What am I missing here?
CT
Message 1 of 9
(4,447 Views)
A 4070 what?
Is this a NI board?
Message 2 of 9
(4,445 Views)
I'm guessing you're talking about the PXI-4070 (great DMM, BTW).  Did you install NI-DMM?  Make sure LabVIEW Support for your LV version is selected to install.
The NI-DMM palette is located under the Measurement I/O.
Message 3 of 9
(4,442 Views)
Sorry, yes NI-4070 DMM. and I do have Ni-dmm 3.0.5 installed. My directory <instlib>:\NIDMM\NIDMM.LLB does NOT exist. Not sure why.
Message 4 of 9
(4,436 Views)
What version of LabVIEW are you using?
Message 5 of 9
(4,432 Views)
I am using LabVIEW 2009 SP1
Message 6 of 9
(4,429 Views)
My Measurement IO menu has only NI Scan Engine and NI I/O Trace, even though I have power supplies, muxes, DAQ cards and DMM's.
Message 7 of 9
(4,426 Views)
I would reinstall the drivers.  It is sounding like you installed the drivers before LabVIEW.  If this is correct, then the drivers would not install the LabVIEW support VIs.
Message 8 of 9
(4,419 Views)
Reinstalling drivers took care of the problem. Thank you all.
Message 9 of 9
(4,406 Views)
