How Do You Clear a Tree ?
Hi everybody !
I know the question looks deeply simple but i don't know how to clear my tree, I mean every time I run my VI, the elements are added, I would like that when I run my VI, the tree is empty.
Thanks !
Lucas
(3,640 Views)
Hi Lucas,
there is a DeleteItem method with the tree.
You can also set an empty tree as default value and call the "Reinit to default" method…
(3,621 Views)
Here's the method Gerd was referring to... wiring an empty string will delete all the tree contents:
Note that reinitializing to default will *not* empty the tree, it will only change the selected row(s) back to whatever the default value is (the initial default value of the tree is that no items are selected).
(3,599 Views)
