How Do You Send the END KEY via Serial?
Hello All,
I'm trying to do something that would seem simple, but is not because almost no information about the END KEY on keyboards is posted online.  Essentially, I'm trying to activate a device that comes out of sleep when someone presses the END KEY through hyperterminal or some ascii based command window.  I'm trying to send that END KEY automatically using Labview, but I'm stuck. So here are my questions.
Does the END KEY have a specific ASCII number?  I'm getting 2 different answers in my search for this one.
If it doesn't, how do I send that command over the serial communications line?
If it does, then what's the best way to convert it to something that labview understands as the END KEY, and not some combo of characters?
Thanks a bunch.
Matt
Message 1 of 12
(5,052 Views)
You would have to find out the character that is mapped to the END key and simply send that out the serial port. You may want to try sending 0x4f". At least this is what I found for the mapping of the END key.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(5,043 Views)
As far as I know there is not an ASCII code for end. Does the device you want to wake up need a character in particular or is that something under your control? There are some "device control" ascii codes but I don't know what they are for and doubt they are mapped to the keyboard. If there is a character that the device does not use such as "&", "?", "*" or "Backspace" then you could use one of those.
LabVIEW 2012
Message 3 of 12
(5,034 Views)
See, that's what I thought, from the little information that I've gotten, is that there is no ascii code for the END KEY.  The device communicates with either a hyperterminal or something called "bb talk", so I'm not sure if there's a character sent after someone presses the end key.  So either the END key does something special to the serial line or there's a secondary character being sent when someone presses the END KEY.  I'll have to find out, I guess.
Message 4 of 12
(5,025 Views)
You should go back and re-read Mark's response. There is an ASCII code for the End key. However, whether or not that's the correct character we cannot tell you. You need to look at the documentation for the device that you're communicating with. The "END KEY" is just a general term. What that actually is depends on the communication protocol.
Message 5 of 12
(5,019 Views)
Is this "bb talk" a program that connects to your device? Connect "bb talk" to another computer running Hyperterm (or LabVIEW) and press the end key. See what characters get sent when you press end. It is likely that "bb talk" intercepts the keyboard scancode for END and then sends some ASCII code.
If all else fails just press the ANY key to continue. Smiley Very Happy
LabVIEW 2012
Message 6 of 12
(5,018 Views)
"You may want to try sending 0x4f"
I will try this.  Thanks!  Sorry I missed this the first time.
Message 7 of 12
(5,009 Views)
smerc,
We're communicating via Serial port, so I would think the ASCII format would be the correct format.
Message 8 of 12
(5,007 Views)
On my system, pressing END on the keyboard while an Hyperterminal session is open sends a 3-characters escape sequence to the serial port:
ESC[K
in ASCII hex codes: 1B 5B 4B  (dec codes: 27 91 75)
I'm not sure it's also valid for all systems
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 9 of 12
(5,006 Views)
@TeknoAXE_1 wrote:
smerc,
This statement makes no sense. It is irrelevant whether you are using a serial port, TCP/IP, or a tin can with a string. The ASCII code does not change, nor does it change the fact that there is an ASCII code for an "END" key. As noted, whether or not this is the code that needs to be sent for your device can be verified by looking at the documentation for your device. Have you done this?
Message 10 of 12
(4,991 Views)
