How Do you use niHSDIO to export generated signals in labview to different output ports ( e.g PFI 0, PFI 1)?
    Im using labview to generate different signals and hoping to use niHSDIO to export the different signals to different output ports ( e.g PFI0 PFI1) using only NI PXI 6552. Im able to generate a signal and export the signal to one output port. However, I have problem exporting 2 or more signals to different output port. Anyone can help? Thanks
(2,656 Views)
Duplicate post. Go here for the duplicate.
(2,641 Views)
