How Handle NULL Return for a C-String Function Parameter for a CLF?
I've got a C function:
Purpose
Returns the "value" (associated character data) for a node, or NULL if the
node has no data.
Syntax
const oratext* getNodeValue(const xmlnode *node)
When I Configure a CLF for that, the natural thing is to characterize the
return value as "C String Pointer" -- but that doesn't allow me (in any
obvious way) to test for NULL (which is not a C String pointer).
If I call the return value a u32, I can do the test, but then can'rt see a
way to cast that to a string.
(I really do believe that the documentation means what is says (ie, aot that
it returns a pointer to an empty
string).)
(2,708 Views)
Apparently, LV doesn't distinguish between the return of a NULL pointer (to
a string) and the return of an empty string.
-- PMH
"P. Michael Hutchins" wrote in message
news:99av6l$4n0$1@news.draper.com...
> Purpose
> node has no data.
> Syntax
that
> it returns a pointer to an empty string).)
(2,708 Views)
