How I Creat a Local Variable to Boolean Key If I but this Boolean Key in Cluster in Fron Panel
I build a cluster on Fron Panel and I put in it Boolean Key (Square LED) .
I want to creat a local variable to this object , how can i creat it.
the option which I get are
Property Node
Reference
Invoke Node
(2,676 Views)
You create a local variable of the cluster first. Then you can access any of the items in the cluster using Unbundle/Bundle or Unbundle by Name/ Bundle by Name tools.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(2,675 Views)
