How I can delete this Warning????
When I use a VI in which there are a suVI of Instrument Drivers compare this message:
RSNRTZ Config Measurement.vi
  Virtual Instrument
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Write And Read Response.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Write And Read Response.vi".
RSNRTZ Error Query.vi
  Virtual Instrument
RSNRTZ Initialize.vi
  Virtual Instrument
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Utility Default Instrument Setup.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Utility Default Instrument Setup.vi".
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Utility Clean Up Initialize.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Utility Clean Up Initialize.vi".
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\RSNRTZ Reset.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtz.llb\RSNRTZ Reset.vi".
RSNRTZ Measure.vi
  Virtual Instrument
RSNRTZ Select Forward Measurement Mode.vi
  Virtual Instrument
RSNRTZ Select Reverse Measurement Mode.vi
  Virtual Instrument
HOW CAN DO TO ELIMINATE THIS WARNING???
THE VI IS GOOD, BUT I DON'T LIKE THIS WARNING ALWAYS I OPEN AND RUN VI.
Vanny
)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(
Sweet, Beautiful and Young Female Physicist (SBYFP)
(I speak a not very good english, so If U are Italian LabVIEW expert speak in Italian, if U speak in Eglish... please speak easy;) )
My e-mail for personal contact: vanessaricciardi@live.it_NO_SPAM_PLEASE
(4,327 Views)
You can ignore these messages once and choose save all.
(4,326 Views)
I did it, but compare always!!!!
Vanny
(4,313 Views)
Try performing a mass compile
David
www.controlsoftwaresolutions.com
(4,295 Views)
Hi Vanni,
as David suggested, the warning should disappear if you mass compile.
In the menu bar you have to select Tools >> Advanced >> Mass Compile and browse to the directory where all the VI of your project are saved.
Serena
(4,256 Views)
See the figure. I use many times the yellow icon, but Can I use only one icon in the for cycle? But I must put, like the figure show, the out of every cycle in one of input of merge icon. It's possible?00000.jpg
Vanny
(4,136 Views)
Vanny,
instead of splitting up your numeric array and convert it into the dynamic datatype using the "merge signals" function, you can use the "To DDT" (to Dynamic DataType)and configure it to "1D array of scalars - multiple channels".
hope this helps,
Norbert
EDIT: Other possible ways to remove the multiple instances of "Index Array" are:
- Use a single Index Array and extend the input "index" by pulling down the bottom border of this function. You then can connect multiple indices. Note that not connecting any indices will work too since LV will use index 0 as first and then increment each index.
- Use an "Array Subset" to read a range of the original array
Message Edited by Norbert B on 02-09-2010 02:24 AM
Norbert
Expert: Geometry
(4,128 Views)
