How I can see my front panel on Internet (IOT in Labview)
I have a front panal of my VI which is getting data wirelessly from myrio through wifi but if my laptop is connected to similar wifi.I want i can access my data any where at any time.How can I? Also i have just seen a video "iPad and iPhone running a remote NI LabVIEW application" on youtube.How should I do this?I dont know the about the application I am using in this video.Please guide me.
(3,367 Views)
I am not sure what a "similar wifi" is. Are they on the same network?
You can use a browser to see your front panel if setup correctly and if using a compatible browser. If things are on a private network, you also need to configure port forwarding to be able to get to it from anywhere. Sometimes corporate firewalls also need to be adjusted.
To share data from the myRIO, you could also have a look at this.
Please give a link to the video you are referring to. Thanks.
(3,351 Views)
I'm pretty sure you won't be able to get a remote front panel working on an iPad or iPhone. They are probably interacting with the LabVIEW application over a standard web service or they are using the Data Dashboard app (I'm not sure if you can still download it though).
(3,330 Views)
