Thanks, but even I did disable the Auto range on X/Y Output Cluster (or XY Graph) in Front panel ... when I created the Output Cluster (or XY Graph) property node, the X & Y scale said only can be read, therefore I can not set the Min/Max as you said (I tried it before) ... might be I forget something?
I attache my improve program (X & Y still Auto range, otherwise it does not work properly when we change the number of reading: use Control bytes in FP when you run), I can initialize the X value and X increment ,but I can not control the maximum values (always show double range?)
*) And I also can not put Y in Min/Max Range as you said!
Please try it & modify it (as you wish, even use different Graph type)
Thank you again, might be you solve my p
roblem this time!
