How Labview stores data in memory - Win32 only
Playing around with some API calls in Labview, I decided to create a few vi's explaining how Labview stores data in memory, how to get data-pointers and how to do API calls that would otherwise be impossible in LV (For example, I have written an FTP client using WinInets' FTPFindFirstFile in Labview).
For more info, refer to Application Note 154: http://zone.ni.com/devzone/conceptd.nsf/webmain/370DFC6FD19B318C86256A33006BFB78/$File/AN154.pdf
Enjoy !
David.
(4,037 Views)
David..
In the application note, it states "LabVIEW stores strings as 1D arrays of byte integers (8-bit characters), as shown in the following illustration. If your
handle is 0, the array is empty."
Is that true?
From my use of LV, I was under the impression that 'other' information is also included (such as string length).
If a labview string of 100 characters and contains an ascii null at position 50, it still prints out the complete string including the NULL. If I pass this string to a C function, it only 'appears' to pass the string upto the ASCII null. (This is more attributable to the C function itself, since I assume LV just passes a pointer to the memory (by ref), or a copy of the data. It is the C functions handling of the LV string that is th
e cause of the 'appear', not a fault of LV.
How does LV handle strings when they contain ASCII nulls ?
What does LV use to identify the end of a string?
Are LV strings dynamically allocated?
etc...
Just curious as to the inner workings of LV thats all.
Regards
Chris
(4,037 Views)
The key here is that this sentence is referring to a LV array of bytes.
A LV array has an int32 count followed by the data. So a LV string
has a count followed by the characters. The strings are dynamically
sized and can contain nulls. If they are to be sent to a C program,
your options are to filter the /0 characters out of the string first, or
send the LV or Pascal string. C can deal with other types of strings,
but the null terminated one is the most native. Its big disadvantage is
that it then reserves the /0 byte and doesn't deal wit
h binary string
very well.
Greg McKaskle
(4,037 Views)
I assume Gregs answer is sufficient, but here's my reaction anyway.
LV indeed uses a different kind of string termination: Size I32 in front of the data instead of the trailing null. So, LV actually doesn't care what chars are in the string, it just looks at the size I32. C does. And that's the reason why many API functions expect a buffer length parameter together with the buffer pointer (Example: GetWindowsDirectory). It's also best practise to fill the buffer with spaces, before you do the call.
What is confusion in AN 154 though is the handle being 0 for an empty string, as you mentioned. I GUESS they mean that the size I32 is zero... not the handle, nor the pointer. At least, that's what my code shows.
Have a nice day,
David.
(4,037 Views)
> shows.
Recently, well within the last few releases, the storage of arrays and
strings was improved to be able to encode empty or zero element length
as being a NULL handle. This helps quite a bit in sparse arrays of
strings and other complex data. I believe that this is often hidden
from CINs and DLLS by inflating them before the call, but it is used
extensively throughout LV.
Greg McKaskle
(4,037 Views)
That might be possible. No way for me to check, since I can not figure out the handle without an API call...
By the way: are you in any way related to NI? You write that much useful info on LV on this board that I can't imagine you're not.
David.
(4,037 Views)
Related? By day I am a developer on the LV team. From home I often
answer a few emails. Since work has a bit of a family atmosphere, I
guess related is an OK word to use.
Greg McKaskle
(4,037 Views)
