How Many Global Variables can be Created in a Single Global VI?
I have a doubt...... i have created a Global VI in that i have placed a Boolean...Like wise how many variables can be inside a single Gloabl VI????
(3,828 Views)
As many as you want.
Of course, this leads to the inevitable quesion of what you're using the global variables for... Global variables, like local variables, can lead to race conditions if not used properly. The LabVIEW Help also has a couple of pages on caveats of global variables.
(3,819 Views)
In pre-LV 8 ( I think!) the size of the FP was limited such that if all of teh controls were is a single cluster that was flattened to a string, the type descriptor had to be less than 65K or ther abouts. Since then the size has been bumped up so...
The limit is now dependent on the address space of the OS and the amount of phystcal memory in the machine.
But the abovve is all some educated guess based on what I know. Since I avoid Globals like the plague, I can't speak from experience.
Ben
(3,790 Views)
I think the answer is: Too many.
Should you manage to fill a VI with globals your program and/or the design probably has some issues. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,786 Views)
