How Read Date with Read From Measurement File
Hello
I try read text file with Read From Measurement File, file have column date and time
06/02/2017 14:34:24 and data
06/02/2017 14:34:25 and data
only read 06 or delete date read 14
Any help you guys can give would be much appreciated.
(4,552 Views)
We can provide much better help if you attach two things:  the VI (not a picture, but the actual .vi file) and the data file you are trying to read.
Bob Schor
(4,515 Views)
sorry.
First Read From Measurement original and copy delete date and time
Copy woth it.
(4,514 Views)
It's because those files have different delimiters.
Original one has "space" as delimiter - and Read Measurement File Express VI does not have such a setting.
The second, "copy" file, has "tabulator" as delimiter - that's why you can read all the data.
You can also read data via function "Read Delimited File" (or "Read Spreadsheet File"), where you can setup delimiter. But then you need to add more parsing to it, to get signal data.
Hopefully, this will help,
(4,488 Views)
Thank you! kosist90
Now I can read the data but date and time does not read. How should I write it or what is the format for reading with Read From Measurement.
(4,465 Views)
