How To Write A Single Number To A Single Excel Cell
I'm using Labview 2013 SP1 with the Microsoft Report Generator and I can't figure out how to write one DP number to one specific cell on an Excel spreadsheet. I have no problem writing arrays of numbers to specific ranges of cells, formatting cells, writing titles, using templates, everything I need except being able to write one number to one specific cell. All the vi's that write numbers seem to demand 2D arrays for inputs. I must be missing something, but I think I've gone through every vi in the MRG pallette and found nothing.
Any help/examples greatly appreciated.
(5,705 Views)
Can you specify a 2D array with just one row and one column?
Alternatively you can use the ActiveX interface to excel.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,698 Views)
I agree with Mike, if you use the Report Generation Toolkit convert the single value to a one row one column 2D array.
Ben64
(5,689 Views)
Accepted by topic author Kilo_Watts
... and you probably know that the easiest way to do this is with Build Array, twice.
Note the lines getting "thicker" going left to right.
Bob Schor
(5,671 Views)
Thanks to all who responded.
A "bogus" array seems to be the way to go. Odd that with all the power of MRG such a simple task requires a workaround. Oh well, the important thing is that it works an I'm sure this will. The double Build Array is clever, I probably would have gone for the Initialize Array, but the double is easier.
Thanks again....
(5,615 Views)
It will help other readers of the Forum who might have the same question to ask if you would mark the Solution.
BS
(5,600 Views)
Done, thanks.....
(5,582 Views)
