How To automate Microsoft Access Forms
I am trying to use ActiveX to automate Microsoft Access Forms. Does any one have any example code of doing this.
(2,809 Views)
Well, not exactly an example, but sort of an answer can be found here. It looks like getting the reference to a form is fairly simple, so going on from there should probably not be too hard.
Another option, if feasible, would be to use macros. There is an example in the example finder of this, but I'm guessing that's not what you want.
Hope this helps.
___________________
Try to take over the world!
(2,803 Views)
