How To create a Buffer Application Program in LabVIEW?
Dear all:
Can someone advise me on how to implement a buffer application for LabVIEW.
Basically I have 2 application programs than run continously in paralell.
1) LabVIEW Data Logging & Plotting Program. It takes 90 ms to excute its code
2) C++ Data Acquisition Program. It Samples the data from a Reflective Memory Card (on the PCI bus of my PC)
at 1ms and creates a Buffer where it store one sample per channel every 1 ms.
I know LabVIEW have the Code Interface Node to call a C program but since both (The LabVIEW and the C) are runing (one slower than the other) in Parallel I need to somehow interrupt the C program from LabVIEW and get from it the data that it as collected so far.
Any suggestio
n will be highly appreciated. I attach txt file with a little more description of the problem.
Thank You very much.
Felix Beltran
ALSTOM Power Conversion.
U.K
(3,239 Views)
Hi Felix,
The best architecture for this application would be to have the C++ program divided into two threads. One thread is continuously acquiring data and placing it in a queue. The other "handling" thread will read data from the queue and serve it up to your LabVIEW application.
Much better than using the Code Interface Node, build the C++ application into a DLL. You can then call a function from your LabVIEW program to start the acquisition, and then calls to the handling thread function will return data to LabVIEW.
I hope this helps.
Phil R
http://www.ni.com/support
(3,239 Views)
Hi Phil:
Thank you for your advise I'll try this way.
I have considering the DLL as well.
Thanks.
Regards.
Felix Beltran
Control & Instrumentation engineer
(3,239 Views)
