How To use or call dll ?????
Hi !
I have created one programm and i have genetared dll of that ( Using
LabVIEW) now i want to call that from vb.net how i can Do it
please help
Thanks in advance
Message 1 of 25
(6,696 Views)
@Anonymous wrote:
Hi !
By reading the Visual Basic Manuals about how to call a DLL and checking about other posts here with specific problems and according examples for this!
Without a specific problem and its description nobody can possibly give you more detailed information.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 2 of 25
(6,670 Views)
You can find a lot of information here.
___________________
Try to take over the world!
Message 3 of 25
(6,664 Views)
The LV DLL is built to expose it's methods as C functions. Thus to call it from VB.NET, you need to use the DllImport statement. I did a quick google search and this is a good, simple explaination on how to use DllImport
Message 4 of 25
(6,654 Views)
i have read that article and tried it out but i am unable to do ?
can any one explain in detail....
Message 5 of 25
(6,615 Views)
HI
I am able to call Labview Dll from VB.Net BUT NOW I WANT TO USE LABVIEW'S GUI IN VB.NET is there any way please reply fast
Message 6 of 25
(6,637 Views)
What was hat tst?
         Now are you going to become a G-Man?
Nishant
Message 7 of 25
(6,632 Views)
That depends on what you mean. You can have a VI front panel appear as a result of a call into the DLL - check the app builder settings and the documentation on how to do that. But you can't get a front panel control integrated into a VB.NET panel.
Message 8 of 25
(6,613 Views)
Brian, this is obviously impossible when the control is part of a running program, but don't the LV style control appear in the list of registered ActiveX controls as ComponentWorks controls? I'm not near a computer with LV at the moment to check.
Nishant, G is the language behind LV and the logo (and signature) points to Superman. As all my icons, this should also be a temporary one.
___________________
Message 9 of 25
(6,600 Views)
No almost all LabVIEW controls are native implementations in LabVIEW itself. They have nothing to do with Component Works or Active X at all, although I guess the Component Works developers did get some inspiration from LabVIEW controls but even more probably from LabWindows/CVI controls.
Exception to this is the 3D graph which is a Component Works control incorperated into LabVIEW through the Active X control container (and my own private opinion about this control is that it sucks in several aspects, being an Active X control is not the least of its faults).
Rolf Kalbermatter
Message 10 of 25
(6,602 Views)
