How access FP.OSWindow property??
Thanks a lot guys for your help.
The only thing I was unable to do is to hide the title bar after the window was already created. After hours of inernet searching, I conclude that it is simply impossible - is that correct? If not (I hope!) - PLEASE tell me the call function :frustrated:
-fomine
_________________________________
You can do greater things with LabVIEW!
Message 11 of 14
(2,183 Views)
Accepted by topic author fomine
Oki, never mind 🙂
Ho-ho, after some more fiddling I got it!
I had to use GetWindowLong to get the style, subtract xC0 0000 andSetWindowLong
Live and learn!
-fomine
Message 12 of 14
(2,179 Views)
Some manipulations to windows are not possible without recreating the entire window. This is of course only doable by the actual application not by some outside application.
And you need to be careful manipulating application windows. Some applications depend on particular states for their operation and get in a turmoil if you mess with that. LabVIEW is for instance heavily intertwined with the floating and other states of windows, and will get really upset if you change some of those properties through Windows API calls instead of through LabVIEW property nodes.
Rolf Kalbermatter  My Blog
Message 13 of 14
(2,171 Views)
Thanks Rolf,
Yes, of course, for the windows I create from LV I use FP proeprties. I had all this trouble only because I had to act on a window which is an exe file for which I don't have source code.
-fomine
Message 14 of 14
(2,161 Views)
