How average in spectral magnitude work in Spectral Measurement
Hi everyone,
I am a Computer Science student and currently working on a project that need to transfer the work done in LabVIEW into other programming language (python).
I was following the tutorial "LabVIEW_Spectral_Tutorial" and instead of calculating Power Spectrum I need the Magnitude Spectrum of the signal. I replicate the tutorial but added a lowpass filter and using Spectral Measurement to calculate the FFT then save the last waveform as txt file. However, in the last block, I do know the objective of the average function but I don't know how it was done in LabVIEW.
Lets say the number of averages is 5, does it mean the signal is recorded 5 trials then compute fourier transforms of each trial, get magnitude spectrum and average this across trials ? If so, how can I extract or save each result of these FFTs ? how do I know when and where the signal is recorded because It was recorded 5 times?
I attached the VI (LV 2012 version) for your reference.
Thank you!
(1,150 Views)
Hi nguyenlk,
When you convert that ExpressVI into a regular subVI (by using it's right-click menu) then you can dive into its "inner" code to explore how NI designed the averaging algorithm…
(Be aware of diving several layers of VI hierarchy!)
(1,093 Views)
