How best to insert a sub-array (row) into a 2D array at the correct index which is depending on the value of the first column
I did this quickly, but someone else may be able to do this better and/or cleaner.
Kas
Message 21 of 22
(878 Views)
You got it! I added this in my VI and works great. Your solution is cleaner than the one I came up with after your 1st example post.
Thanks so much.
BR
Message 22 of 22
(871 Views)
